i have a 86 2.5l 4x4 2 door xj with a 4spd stick. anyone know what a 245/75/15 tire is in inches? im lookin to get a set of bigger tires at the junkyard to beat on. i know with certain gears its hard to turn certain tires. i have 215/75/15 on it now. im just tryn to clear some of the bigger rocks on the trails
You may already know, but the larger the tire and the smaller the diff ratio generally are bad. So first find out the gear ratio you have then you can determine what the best tire diameter for that ratio is.
There are many many tire size to tire size (in inches) calculators, or tables on the Internet. If you can't find out tell me and I'll post some links up for you.
There are also calculators and tables that tell you the best size tires for your gear ratios.
When I decided to go to 32" tires, I looked to see what the best gear ratio would be. I had to read it and decide for myself. I wanted a ratio that would be good on the trails, but still perform well on the highway. It looked like a 4:10 was the best way to go, but I was advised to go one lower, so I went with 4:56 gears.
This is great because even though I turn 3000 rpm at 80 mph my plan WAS to go to 33" tires later, now that I have more experience with the 32s and the height of the rig, I want to go a little higher and a little bigger with the tires.
I'm now thinking about 6.5" of lift and 35" tires. Checking one of those tire size gear ratio tables, I'm still good.
ok found the tag now how do i tell which trans i have. are all the 4 speed sticks the same? i gotta clean the tag to read it lol.
by the way im turning 3100rpm at 60mph the 4 wheel shop says i should have a lower gear than 4:10
Well maybe that is right for a standard transmission. I have the AW4 with over drive and I turn 3000 rpm at 80 mph. At first glance I'd say 4:10. Look for the tag on the differential, not the transmission.
If you have a digital camera, takes some pics and post them here.
You may have to do what someone else said. Raise the rear rotate the tire/wheel and count how many times the drive shaft turns.
According to the chart, with 30" tires at 65 mph 4:10 or 4:27 for a rpm around 3100 rpm. You're doing 60 (is the speedo corrected) so that would lean towards the 4:27
haha yep!
its a 35 no doubt.
whent wheeln tonight, night wheeln popped my front tire off the rim used the donught which was flat and my lil compresser sucked. got to a gas station and oiled up the rim and leaned the tire on my other one and got it to pop back on the bead!!!
i picked up my teraflex 1 1/2" front coil spacers for $56 at the local 4x4 place on my way to reiter pit so all in all good day. learned about rears and gears, wheeled, met some jeep guys 2 days in a row, fixed my tire what more do ya need
i love this forum by the way!hmm maybe i have to get some stickers,lol
can a stock xj clear 31's with no lift?i hunted for tires today at the boneyard ALL I FOUND WAS ALOT OF 235/75/15 STUFF and a 30 on a newer jeep rim. im tryn to get a set of 31's from a guy i met out wheeln so im wondering. i have a set of teraflex 1 1/2" coil spacers i just bought but havent installed and the 2.5" blocks in the back on my flat leafs. i picked up some comanche shackles today as well
Sure, the 31's will fit, but they'll rub. They'll rub on the LCA's and against the fenders. Don't think about flexing the suspension with 31's because they'll rub pretty bad. Your best bet is to at a minimum do a 2" lift and trim the fenders some to minimize on the rubbing issue. 3" should be just perfect for that size tire as well.
that sucks...will 30 9.50 15s rub? why do the 31s rub on the LCA's? is it the width? i have seen a 31 10 and a 31 9.50 . well im not sure what ill get with the teraflex spacers in the front but the back is up maybe 2" and if i hang the comanche shackles from the xj shackles ill get another 1" im geussing so im wondering how to get the front up 3" without new coils. i havent seen more than a 2" spacer for the fronts and i doubt its safe to stack two 1 1/2" spacers on each side?
I have 30x9.50x15's on my 00'. My stock suspension is in good shape,These tires rub slightly!! its a pain when your in the woods too.
the pic in my avatar is the old stock steel thread comin through tires. i think today I will take a new picture of my jeep. Hope u find the tires you need!!!
Related Threads
Jeep Cherokee Talk
409.2K posts
28.4K members
Since 2008
A forum community dedicated to Jeep Cherokee owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more for the SJ, XJ, KJ, KK, KL series and Grand Cherokee!
