Hello, I have a 2002 Jeep Grand Cherokee 4.7V8.
The factory fog lamps do not turn on. I have a good service
manual and I want to check the relay in junction block C2.
I can't find where it is. Today if it does not rain I will have time to
work on it. If some one knows where this relay box is located please
let me know.
Thanks!!
IIRC it is drivers side under the dash to the left of the steering column
Solved: Thanks for the direction, I did find it and the relay is fine. I later found a bad splice of the front wire harness. Ill remove the battery and its tray to see if I can add a connector.
