I already have sway bar links on my Jeep Cherokee, but when I purchased it they were disconnected. I have no way to reconnect them to the bottom mount because I can't find the hardware anywhere online, just a entire kit, which I don't need. Any help?
The hardware on the bottom is just a bolt. Find one that fits the bushing snug in side and goes all the way through so you can put a nut on after it goes through the arm on the axle
Reactions: CoffeeAndJeeps
Thanks for the help! I had talked to a few friends and we weren't sure if there was some metal sleeving that came with the original parts and weren't sure just a bolt would work.
The original bolts were splined on mine and had to be torched/hammered out. A regular bolt that fits will be just fine. Mine are now customized 7/16" bolts with jam nuts holding them in place so I can use them as quick disconnects.
