381 - 392 of 392 Posts
I have stiffened my frame, glad I did
Reactions: DaingMaing
Discussion Starter · #383 · (Edited)
Another little update which I already shared in the WDYDTYXJ thread is my clock/switch plate.
It's pretty cool, wired into the light switch so it dimes slightly for night driving.
Discussion Starter · #385 ·
So I guess I'm reviving an old thread, sorry guys, I haven't been very active on CT. But I still have my rig and still want to be a part of this great bunch of 4x4 enthusiasts.
I started experiencing a lot of front end noises with my rig. Popping and it seemed to be coming from several places in my steering system. Because I always go wheeling on new years day I needed to adress my concerns. I found a lot of problems that all probably contributed to the problem.
1rst, I found that the holes in the lower control arm brackets on the axle where wollowed out. So when I backed up the axle was shifting on the bolt, I'm sure contributing to the popping noises. I took four thick fender washers with a smaller size hole and drilled them to the exact size of the bolt. Welded them to the bracket to fix the slop.
2nd, I found the track bar I put on which at first was great, but as time went on. The Johnny joint had frozen up from moisture, I even lubed the joint almost every time I took it wheeling. I think they are junk. Solution, well I was extremely fortunate to come across someone who was selling xj parts from his storage garage. I bought a used track bar and bracket from him for $80. It wasn't as simple as unbolting and installing it because I weld my previous bracket with 1 inch welds to insure it doesn't go anywhere. So an afternoon of cutting and grinding with my angle grinder I got it removed, of course I welded the others bracket the same way.
3rd thing I did was replace the lower control arm with none adjustable ones. The control arms ctrl I had would not lock solid with the jam nut. So there was movement in the arms. I feared that some day they might wollow out and separat. Like what happened one day a MJ on a trail run I went on. I had to a l so do some adjustments to the upper to get the pinion angle right.
After doing all this, I am pleased with how it now drives and the noises are pretty much eliminated.
Glad you got it sorted out. Have you tried waterproof grease. I live in a drier area, but my flex joints, though larger than Johnny Joints, never have a problem
Discussion Starter · #387 ·
I really don't know why they end up seized up, but it is not isolated to my track bar, a friend has basically the same setup (just different brand) and his is seized up as well. The trackbar I got is a Rough Country track bar, it has rubber clevite bushings, hope they are less prone to wearing out prematurely. But it really isn't a very expensive unit to replace if it does. We'll have to wait and see.
Interesting.
Grass Tape measure Font Auto part Fashion accessory
These are the joints my track bar is mad of. Greasable, adjustable and all plated. Never had a problem with them. Bought some more to make more suspension goodies
Discussion Starter · #389 ·
I'll have to try and take a picture of mine. I can't even pry it with a long screw driver to get it to move. That's how frozen up it is. I also think the new track bars bracket lines up much better with how the axle moves up and down.
I think that a person gets what you pay for too. The track-bar that I had purchased was something that looked great off ebay, but I should have ponied up the first time and bought one from a more reputable manufacturer. Hate being on a budget!
I understand budgets entirely
Might look into Duroflex joints from metalcloak. No maintenance required. And they flex like crazy. Glad you have the problems sorted for the moment!
Discussion Starter · #392 ·
Yeah for the moment, wheeled it on New Years day and have been enjoying driving it back n forth from work. One small detail on my alignment is that the steering wheel needs to get realigned. But it has bottomed out so I need to remove the side threaded ball joint end that goes to the pitman arm and do some shaving, then it will be good. I just engore my OCD and enjoy driving it in a straight line without have to pull it back to center on the road.
