So the guy I live with is convinced that all that is wrong with my xj is a fuel pressure issue. He says I can test my fuel pressure using my voltmeter and I don't need to go out a buy a fuel pressure gauge.
if you can I don't know how since the fuel pressure regulator has no electrical wires to it so I don't know how you would do that but then again you have a RENIX so it may be possible..
Thank you!! Now will you tell that to the guy I live with???You have to have a pressure gauge to check any of the fuel system
You are correct to check fuel pressure gotta have a gauge..Like the post above you said you can test the sending unit with a volt meter but not pressure..Well unless there is some voodoo magic I don't know about and I have been known to be completely wrong so who knows..You have to have a pressure gauge to check any of the fuel system
This is the truth, no way to check with a volt meter.You have to have a pressure gauge to check any of the fuel system
Seriously! Just tell him to shut up, look pretty, and fix you a samwitch! :rofl:Huh???? Is this the same guy who told you to find a code scanner for your Renix???
You need to tell him to stop trying to tell you things about your Jeep. Let him know you are going to ask us, cause we will give the right answer.
There is no way to measure your fuel pressure with a voltmeter, or an ohmmeter.. unless they are tied to a fuel pressure tester.
The Renix fuel pressure regulator only has a vacuum connection to it.
While you are testing the fuel pressure also do a flow rate test. This will give you an accurate picture of whether your fuel pump is getting the job done.
Autozone used to have fuel pressure gauges on their loan a tool program. Go in plop down a deposit and use it. Return it when you are done and get your money back
Tell him to take the schrader valve out of the fuel rail and have him put the end of the fuel rail in his mouth as you try and start it. If he starts spittin and cursin you have pressure it just may not be enough!
J/K
This is not recommended
Really the only way to test is with a gauge.
J/K
LMAO
