1 - 7 of 7 Posts
So I have a 95 Cherokee 5 speed 4x4 with 94 4.0 I need to swap the fuse box an possible wiring harness so am I able to use all that from a 92 Cherokee 2wd automatic thank u in advance
227486
227487
227488
Was that under water? It Looks like a lot of grease was sprayed on it. Which can be cleaned. Switching out those fuse boxes and wiring harnesses is going to be a sucky job. The harness/fusebox may work throughout those years, but your also going from automatic to manual and from 4x4 to 4x2. It may require a bit of hackery.
It sat in a barn for 14 years other than that so I believe that may have caused some other then that idk
Is that your concern? All the corrosion? If that's the fuse box in the Jeep you are trying to"fix", I would try to clean that up first. Disconnect the battery first. Then spray it down with battery corrosion cleaner. Then use a little wire brush to knock off the heavy stuff. Some brake cleaners might be hard on the plastic, so be careful of what you use. You already have a pic so don't be afraid to pull all the fuses and give her hell! :)
Yes that's on the one I'm trying to fix there is a melted fuse in the one of the slots also my lights dash lights and gauges do not work
Is your 1st pic the bulkhead connector that goes through the firewall? When I rewired my buddys truck I bought a bunch of wire ends from a place called Del City Electrical Supply. I got wire, crimp on connectors, bulkhead connectors, and fuse boxes. I already had the proper crimpers. So if the fuse is melted into the slot, you can pop out the connector and replace it. I would rather change a few wire ends, then replace a fuse box or harness. Unless the harness has melted wires. The gauges could be a connector issue. pull the cluster and unplug then plug the gauge cluster wiring connectors, I think there are 2. this usually fixes the dash lights and gauges.
I'll give that a shot I appreciate it
1 - 7 of 7 Posts
