Hi,
I have a 1992 Cherokee XJ 4.0 L Limited, with the rear-right indicator that no longer works.
A month ago I had managed to make it work by putting contact cleaner in the connector on the left side under the fuse box. It worked for a while, but now it's stopped working again.
When switch on the hazard lights, all indicators work except the rear-right.
When I move the indicator switch to the left, left-side indicators work ok.
When I move the indicator switch to the right, the front-right and right fender indicators work ok. However the rear-right doesn't, nor does the right nor the right-turn light on the instrument panel.
The symptom is that of a defective bulb, but the bulb is ok, as is the bulb holder.
I removed the interior trim and followed the wires, putting contact cleaner on all connectors up to the one on the left side under the fuse box.
If I unplug the connector just upstream of the rear-right light cluster, I have intermittent 12V on the tan/green wire (which is connected to the tan wire to indicator bulb), so that's ok.
However, if I reconnect the connector in question, I no longer have power on the tan/green wire. If I unplug the connector again, there's still no power on the tan/green wire. If I leave the connector unplugged for some time and turn on the hazard lights again, I have power again.
I'm utterly confused. Has anyone got an idea?
Do you have a trailer pig tail? Do the brake and reverse lights work on the right side?
There is a ground for those lights. Make sure it is clean. Sometimes the sockets get corroded. And the springs get weak.
Yes, all other lights of the rear-right side work. I do have a trailer socket.
I’m surprised to see that the ground from the wiring (black wires) do not appear to be connected to the bodywork. Is this how it should be ?
Actually the ground from the wires is connected to the bodywork, but there´s 5 ohm resistance in between.
That seems like a lot for a direct connection. I would clean your contact point to the body and retest. Could be corrosion giving you grief.
Reactions: Gluckmysock
