1 - 20 of 32 Posts
how many of u guys are running 4.5-5" of lift w/ just a tc drop and are fine? i know every xj is diffrent, just getting an idea. heres my situation
right now im on a 3in RC lift and 31's. No vibes yet
Getting a good deal on some 33" procomps next weekend.
now i have 500 to play with to lift my xj another inch or two.
I really want to go another 2" so that would put me at 5" and get a tc drop and see whats up then but im afriad of vibes and considering just another 1" and a Tc drop.
I will atleast be buying some new lower control arms, Adj. track bar, brake hoses.
Sorry if this seems to be confusing. my main question is, is there a possability i will be fine going up 2" with a tc drop of should i just go up an 1" and do a tc drop. I would go ahead and do a hack n tap but im limited on funds b/c of getting laid off here soon.
Web Wheeler
Well first, if you are getting laid off you shouldn't be spending your money on your jeep, lol.
Right now I am running about 5.5" of lift with just a tcase drop and I do get driveline vibes. I have a 93 and I am getting driveline vibes, so you should definitely not do it because you have a 98. Newer Xjs are more prone to driveline vibes.
Transfer drop case here. It was smooth until my front tires started scalloping. I had them balanced and moved to the back. I have vibrations now that I "believe" is due to the rear tires.
I'll be doing the SYE on my NP242 but I don't think the vibes will leave until the tires do.
I guess I need to do some burnouts. ;)
right on. i think im going to try it out and run it with a transfer case drop for a little bit. if the slip yoke is out way far and the vibes are bad, ill do a hack n tap.
Get a set of Rough Country or Rock Krawler shackles. They are adjustable 1.5" or 2" it also changes your pinion angle a slight bit and that will help with vibs and will also help with the ride and flex.
I have over 6" and mine is fine...
whats a hack n tap? where you change the angle the rear end sits? by cutting the leaf plates and re welding them?
Web Wheeler
Just a heads up, I wouldn't do any more lift with your current setup because newer XJs are more prone to driveline vibes.
Discussion Starter #15
yeah i know the 97^ are more prone to vibes then the older xj's. Like i said, i think im going to go ahead and do the +2 w/ a transfer case drop and see whats up. If its horrible ill just take the spacers and shackles back off until i get the loot for a hack n tap and a front xj drive shaft. Just got the 33's on today and i am going to have to go up another 2"
Discussion Starter #16
def needs another 2in. rear is sagging in the pic a little due to my old tires still in the back.
Discussion Starter #18
u think so? looks kind of..... not right?? to me for some reason. once i take the tires out it will be fine. my old 31" treadwrights were f'n heavy!!
:brickwall:
This looks like the one's that came with with my RC 4.5" AAL kit.
you have a np231 tc so you dont need a hack and tap just a sye.
1 - 20 of 32 Posts
