Well as posted earlier, my son and I were looking for a lift for his ZJ. He settled on the BDS 3" kit as it was in his budget range, a decent quality base lift, and the BDS guarantee is exceptional.
So this weekend, myself and my 2 sons took on the task of installing the lift. Overall I would have to say that this was one of the simplest installs I have ever done. The ZJ is a pleasure to work on compared to the XJ! It seems on the XJ I have to fight for every scrap of success whereas the ZJ gave up it's old parts almost willingly!
There were of course the usual stubborn bolts requiring a torch-heating festival, but hey, that's time a guy can lay down rest while heating up the bolt
There was one that we cut right off as a replacement came with the kit.
Because he was going up to a 32x11.5" tires from his stock 28" tires, there was a butt-load of cutting and trimming that needed to be done. Once the lift and tires were in, he could not really drive it as the rubbing was insane!
SO, Day 1 and 2 were spent installing, and day 3 was the fender trimming day. He wanted to retain as much of the stock lines as possible, so I had my work cut out for me to get enough fender away as possible and not butcher his lines and trim. Overall it turned out very well.
We had to cut the seams in the fender well, so they needed to be welded when we were done. The Lincoln earned it's keep and the new welds are way stronger than the factory welds ever could be.
So without further blah blah blah. here are the pictures ...
The sacrificial virgin ...
The stock suspension ready to come out ...
And old suspension gutted ...
Had to drop the axle almost to the ground to get the new springs in ...
Drilling for the new trac-bar bracket ...
And installed ...
Moving on to the rears ... same as above minus the steering ...
More to come ...
And installed ...
More to come ...
