Well, I was able to locate a used set of 33x12.50_15 cheap. I only have a 3" lift. What the minimum height to make them fit? Would a lot of trimming be needed at 4"? As for wheel back space, which one do you prefer, 3.75" or 4"?
I'm running a budget boost, so all I'll have to do is re-stack the rear leaves and get a long coil spring for the front.
Also have a TC drop. Planning on using the front DS from an automatic for the SYE setup.
Not sure if drilling another hole for the track bar would work at 4", if not, will have to use an adjustable track bar.
Planning on making sway bar disconnects. Unless I find a used set somewhere.
Extended brake lines.
Don't know if the stock lower control arm would work.
Using JK shock, hope they work on a 4" lift.
Not sure what else is missing.
Your input would be great. Also pics with anyone running 3", 3.5" or 4" with 33"
Thanks in advance...
