My Dana 35 is going in my 97 and I was checking out an 87 Dana 44 to swap over but have also found a 99 8.25 which should have the 29 spline shafts. I am running 33x10.5s so it should be strong enough and discs are an easy swap but from what I have read I have a few questions. I have about 3-3.5" of lift and am running an Iron Rock Hack and Tap with a stock XJ front shaft, this should still be okay with the longer pinion of an 8.25, right? Also I believe the tubes are bigger so I will need the 8.25 u bolt plates and u bolts as well, right? or can the D35 u bolt plates be drilled out to work? Also I think I read the 8.25 uses a 1330 series u joint, is this correct as my D35 uses a 1310 so I would need to run a conversion u joint on my rear shaft or can I swap the yoke over from the D35 to the 8.25? The brakes on the 8.25 and D35 are the same right so I can swap over parts if I get an 8.25 without brakes I can use my D35 stuff till I get the parts for a disc swap. And yes I have searched and can't find exact answers to all these questions so any help would be great as I need to get a rear ASAP.
